big jon's 240 »
https://forums.nicoclub.com/big-jon-s-240-u1784.html
Fri Feb 07, 2003 1:55 pm
First off, periods are your friend, use them.I believe you will need a new ECU (somebody correct me if i am wrong). Having JWT redo your ECU will not solve this problem. Your best bet is to hit up the junkyards, as a new ECU will cost you an arm and a leg. EDIT: However all this might be irrelevant, as your 97 ECU should hook right up to the 95 KA, i dont believe there is any difference between the motors. Sorry i didnt read your post right the first time.
