magic_max »
https://forums.nicoclub.com/magic-max-u59768.html
Thu Mar 15, 2007 4:12 pm
Hi all! I'm a newbie to this forum. From the threads I've read so far, this seems like a really friendly forum. I've been a member of the maxima.org forum (since 2002) for a while. Anyway, on to my problem.... I used the search and had 1 result that had a similar problem but I thought it would be better if started a new thread instead.
#####################My car stalls at random. Coming to a stop or during acceleration. At times, I can be driving on the freeway and for a split second, seems like the air or gas flow stops and you will feel the car jerk. Other times the car sputters and stalls, other times I don't feel it sputter but the steering gets tight and I know the car died---this happens when coming to a stop or driving slow so far.
I've done these simple things to try and solve the problem:
1) No engine check light and no codes using OBD-II reader.2) Replaced fuel filter (Nissan one).3) Removed throttle body and everything before it to the air scoop and cleaned it thoroughly. Air filter is fairly new.4) While TB was off, shot TB cleaner into the intake manifold and at I think the IAC valve4) Seafoam through the brake booster line5) Sprayed the MAF sensor with Throttle Body cleaner. (I'm aware that they have a MAF sensor cleaner but NAPA was out at the time. I've cleaned the MAF sensor with TB cleaner in the past with no problems and no check light this time.)
Car info:a) 117k milesb) 60K tune up at ~65-70k. Did not do 120K tune up yet.c) Auto transmission, stock air box and stock intake, disposable air filter.
Getting desperate, please help.
thanks,magic_max
