Newbie that needs help
mirakulist
Car: hip-hop and mah car
I just got mah car last month and it has 163k miles, I was wondering if it's worth fixing up mah engine or should i do a dohc swap? And if it's cool to fix up mah sohc what should do first? Sorry for askin, u guys probably r like f*** this newbie. Well, for those who help thanks! :)
7thGear
Car: 1983 Porsche 944
take out your engine
take everything out
buy a new version of everything that you took out ( except the crank... you can keep the crank)
bore the engine just SLIGHTLY to get out all the bumps and grinds
put everything back together
get a new clutch and flywheel
put the engine back in
your good to go for another 5 years or so
silviaNE
Car: cars what else?
If you are interested in SOHC power, talk to ADAMHU, he is one of the moderators at nico. He has one killer single cam. Try searchs on motor rebuilding for some good tech info.
