xxdjstriderxx wrote:When the key is turned in accessory mode, the engine check light stays on. When I start my car, it is off most of the time, but every here and there it will turn on. Someone told me that if it comes on anytime during the smog check, you get an automatic fail. Can anyone verify if this is true or not? My engine runs fine, but my friend told me the light turns on sometimes because I need to clean out my breather box and EGR valve. If this is so, where could I go to get it done and about how much would it cost? Can someone please give me their opinion, or verify any of this info?
I just need to figure out what I need to do to pass smog so I can go ahead and transfer the title and register the car to my name. My engine runs fine, no sort of odd smoke. It has an aftermarket air filter (just the filter) which replaces the stock airbox. It also has a breather filter attached to the breather hose. The check engine light turns on once in a blue moon, which a friend said was due to the breather box being dirty, and a dirty EGR valve. Any help would be greatly appreciated. Thanks.
Yes, you will fail automatically in cali if they see the CEL. But that depends on where you go. Come on man! you're in LA, there's plenty of places to pass . The filter itself will be fine because you only did the filter, not the CAI. You shouldn't run into a problem unless it's a very stuck up the *** place.
Just do the basics before you smog, like oil change, 91 gas, octane booster (just in case), warm up car for 15-30 minutes before bringing it to the place, etc.
