Newbie Qx4 questions
falcon007
Car: 01 infiniti qx4
I cleaned the MAF and retitheng the ground screws n the still came back on...what else would it b?...mayb a sensor?
falcon007
Any ideas of why my car is doing that...and lately the car its been turning off all by itself so I shake the battery cables n it turns on does that mean that I have to change the battery wires?...the code in the computer still says primary ignition signal?
Randy K
Car: 2002 QX4
Ok bleed the brakes according to the sequence you mentioned. Except, mine has no LSV bleeder screw. I see the block where the 2 rears meet and join into one line to head forward, that's the obvious place for it to be, and I don't have one. Mine's 4wd too. Still get the codes, so I'm still thinking it's a short in the actuator.
Falcon if you can shake the wires and it works, yes, try tightening them up or replacing them. Pretty easy to eliminate that as a cause.
