rydwhite »
https://forums.nicoclub.com/rydwhite-u7666.html
Wed Sep 06, 2006 4:12 am
Welcome to NICO.
I don't know of any aftermarket clocks that will fit. You're basically stuck with it. The car handles alright in the snow. A lot of it depends on the tires. A good all weather tire will handle alright, throw a a couple of 40lb bacgs of sand in the trunk and it will help, but here in Indy you shouldn't have too much of a problem. There are snow tires available as well if you feel the need.
The Cold Air Intake does make a difference, it is noticeable and the car does sound better in my opinion. It is usually a cheap and easy mod to do. There are a ton of threads on here about which intake to go with and the pros and cons of them all. So, do a few searches and you should you have all the answers you could want regarding intakes.
Where about in Indy do you live?
