Hi I'm a new owner of the 2012 Quest. I have some questions for the board.
1. Where is the oil filter? Is it accessed from the top or the bottom of the car? Is it easy to remove simply by reaching it or do I have to learn contortionist movements?
It is located behind the front passenger side wheel well. You can either change it from underneath or if you turn the steering wheel all the way to the left you may do it from the side. There is a wheel splash shield that needs removing( that is held by plastic rivets). I use the latter method.
2. It's not playing my Pandora. I thought it had bluetooth. Not sure if this is user error. Any advice?
Not sure about that. Do you have the technology package ( music box, Bose etc?)
3. Anyone have any experience with Portable Cargo Organizer?
http://www.nissanusa.com/buildyournissa ... ries/index I'm trying to find out if this fits the space underneath the floor board behind the thrid row seating or if it's supposed to be on top of it.
I believe it goes in the well.
4. How do I access the cabin air filter? Is it easy to replace on my own or do I have to get it done at the dealer. I'm about basic level handy (I can do simple oil and filter change on my own).
Yes, very easy. Takes 2 minutes to do it. It's a bit tricky to wiggle it in, but the filter is flexible which helps.
5. What is your MPG for 50/50 highway/city driving?
My wife does mostly highway (90%) and she gets 22-23 mpg, but she drives fast 75-80 mph.
Thank you. I'll contribute information also as I learn more about the car in the future. I hope this is a long and trouble free relationship.
