top_secret »
https://forums.nicoclub.com/top-secret-u35327.html
Sun Jan 08, 2006 10:41 am
read through the forums, some of them tend to leak where the glass meets the top but most of them are fine. just about any stock top is gonna need a new rear window, it will be hazed for sure and probably cracked. the rear windows are also a definite problem area as they are prone to seperating from the track, etc... and replacement parts are impossible to get (and the windows are nearly impossible to service
other than that just typical s13 stuff, TC bushings and driver's side seat bolster..
btw I should point out that if you are buying locally its not real likely that you are gonna have a huge group of cars to choose from... not a whole lot of s13 verts around, even fewer for sale.
if you can find one with a good top that works correctly and has rear windows that go up and down then you'll be ahead of most.
Modified by top_secret at 1:27 PM 1/8/2006
