evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Feb 20, 2007 10:23 am
the traction control can be helpful on the street for an unskilled driver, for any performance application it sucks, the tire feathering is an alignment issue made worse by lowering the car, it can still eb corrected but will require extra work to stretch the tire life, all but the base models got the LSD, and the track model got the brembo brakes, the downside si taht the brembo's are only marginally better than stock, the plus is that if you upgrade to something better youcan sell the used brembo setup for aobut 1k on ebay, some of the models came stock with 18's, the newest GT comed with 18x10's in the rear, they kinda skimped on the tire, there is room for a bit mroe tire but not as much as should be on a 10" wheel, if you're planning a lot of mods it might be cheaper to buy a base model and install your own aftermarket LSD, also depends on if you plan on doing any sanctioned racing or if you just want a street cruiser, what woud you liek the car to do?
