newbie question..i want to install a set of fog lights on my rogue and was hopin
cons
that someone can refer me to what brand of fog lamps you guys had luck with.. thanks for any info....
philipa_240sx
Most of the off the shelf fog lamps are junk IMHO. They rust out quickly.
The best option is the OEM Nissan fog lamps. They fit the bumper cutouts perfectly... you just need the wiring. Some of the earlier model Rogue's came pre-wired for fog lamps. However a few members have confirmed their Rogue's did not come with wiring.
You can read more here:
zer...rogue
As for aftermarket fog lights, I have not had alot of luck with them. Many are cheaply made and rust out quite easily. Hella (Brand name Hella, not the Optilux series) are supposedly very good.
cons
thanks i was leaning towarrd the oem fogs. I will probably purchase them this weekend. thanks again
philipa_240sx
Part no's for OEM fogs are in the link I posted above.
Like I said, some early model Rogue's (08's?) were pre-wired for fog lights. However, it appears some of the later models did not. Read more here:
zer...ation
If your vehicle did not come with the wiring and are good with electrical stuff, it's easy enough to wire the necessary relay and switches. You can purchase an entire 'kit' for wiring fog/auxiliary lights from many auto parts stores. It will come with a relay, switch, fuses and wiring. Here is an example from Painless Wiring Products:
http://www.painlessperformance...30803
Auxiliary Light Relay Kit w/Switch #30803
Return to “Rogue Forum”
