Aussie Oi »
https://forums.nicoclub.com/aussie-oi-u143168.html
Mon Sep 14, 2009 2:55 pm
Gday all.Ive tried searching here and reading through countless posts, but im very new to turbos so im struggling to make sense of much.
The story... (Feel free not to read this bit)A couple of mates and I recently purchased a ute fitted with a CA18DET for some off-road racing.
It was breaking down not long after spooling up, and we knew the turbo was tired, but took it for a run, then parked it.
Next day... Checked for fault codes, changed coil packs and fired it up, ran it for a little while and it started putting out the most impressive cloud of white smoke ive ever seen.
Started pulling shields and stuff off and found the air line which was meant to open the wastegate was broken...
That explained the breaking down once it cut fuel with too much boost.
Anyways, checked out the turbo and it was leaking oil into the exhaust... The impressive smoke problem.
My questions...
I cant even figure out what the hell this turbo is. I assume a T25 purely based on that seems to be what they had standard. Any easy ID ways?
Ive gathered a T25 or T28 is fine to bolt on to replace the old turbo. Are they all watercooled?
Is there any advantage to running a T28 on what is primarily a stock motor?
What is this AR number all about?The old turbo had AR48 stamped on it, and i had a look at another T25 which had AR80..?Whats better or worse or acceptable to run?
Are there any differences between T25's aside from some having a flange on the turbine inlet?
Any other helpful hints you could throw at me would be much appreciated too.
Cheers.
