ThisIsSparTTa »
https://forums.nicoclub.com/thisisspartta-u210180.html
Sat Jan 10, 2015 9:37 am
For the lifter, there isn't much you can do unless you want to take the heads apart to rebuild them yourself. Try some of the stuff they sell in the store to fix this.
For the lights, you could try a different timing control module/unit. They are behind that trim piece that covers the drivers kick panel fuse box. They are a common failure point.
Otherwise, grab the FSM, go the electrical section. Print out the first part of it with the overall diagrams, and then whatever sections talk about controlling the interior lights, like the timing control module section. Grab highlighters, trace down relevant circuits, then start chasing them down using the voltmeter to check for voltage when the key is on, and continuity mode to check for connections to ground on positive lines when the key is off.
