pervaz88 wrote:Hi guys im new on here and i purchased a 06 special edition nissan altima and im using the standard speakers but lately i hear one of them are sounding a bit fuzzy. So i wanted to check it out n e one have n e idea how to get into the door panels...also Since im a student at the time being im on a budget....I have no idea on what i would need to hook the system up i have i believe a legend amp...so if im starting from scratch...i want to spend less as possible ne way i can buy a amp and use it with original speakers or just use the amp for only bass?...what would i need and wats good economically...thnx in advance
Ok, lots of questions here, so let's see if I can help. First, you should be able to locate a service manual for your car somewhere. That's probably your best bet for determining how to remove door panels. Unfortunately, I have a newer coupe, so the way I removed my door panels is certainly not the same.
Second, for the amp, it would be helpful if we could have a model number. Try to find it and get us that info. I can't say I've ever heard of Legend, so it'll be tough for me to guess at what you currently have.
Finally, we'll be able to help a whole bunch more if you give us a better idea of your budget. I understand being in school still, however, different students will still have differing ideas of "cheap". All of this info would help greatly when it comes to me being able to give some recommendations.
