_XLR8_ »
https://forums.nicoclub.com/xlr8-u131430.html
Mon Apr 20, 2009 4:41 am
Another question (not sure if this is the right place). I am using a 1996 JDM Cima (VH41 Auto) as a donor and want to utilise the factory A/T Control in my conversion and all is going to plan except I have 2 wires that I cannot identify and 1 that is missing. 1st is coming from pin 36, the second from Pin 42 of the A/T Control (According to every diagram I have accessed both these pins should be empty) and the wire that should be at pin 47 (either for TSC or Active Suspension Control depending on diagram) is not there. One could assume that 42 is replacing 47 but when I assume, I'm usually wrong.
Any help would be greatly appreciated
Modified by _XLR8_ at 8:26 AM 4/20/2009
