AlexM. »
https://forums.nicoclub.com/alexm-u169136.html
Sat Nov 19, 2011 5:31 pm
I wouldn't say "they will not work". Like dzeph said, the weight distribution is different so the spring rates might be different than what a sedan's application would normally come with. So your ride might be more stiff or less stiff than it should with the proper rates. OR it might be the same. BC Racing only makes one application of coilovers for the sedan / coupe, so the spring rates might be the same for both body styles of altima, or BC might just not have developed two different spring rates for the different weights.
