Newbie needing help on Power windows
De-Marko
Car: 1996 240SX SE
Hello all, new to the forums and Nissan ownership.
About two months ago I picked up a '96 240sx SE. It's a good handling car and I like it except for the power or lack thereof. There is a couple of issues on this car that need to be fixed and one of them is the passenger power window. It does not work. I replaced the window motor thinking that was it, but no, it didn't help. I have read about a window amp on this website, where would this be located and where would I go about finding one? Junkyard special? Interestingly, when you pull up on the window button as if you were going to raise it, there is power, but none when you push on the button for it to go down. Is this a common problem? Thanks for any help.
Kalypso
check the tech articles there is one in there on repairing power windows.
De-Marko
Car: 1996 240SX SE
ok, I have had the door panel off on my '96 and I can't find that power window amp. Where would it be?
vancouverbc
Car: 1991 240sx
De-Marko wrote:ok, I have had the door panel off on my '96 and I can't find that power window amp. Where would it be?
it doesnt have an amp. 95 was last year for amp.
vancouverbc
Car: 1991 240sx
zerothread/256110
heres a tutorial on your windows. make sure you dont have the passenger window lock on. i dont know what you mean by pulling up on button and there is power. the window moves?
De-Marko
Car: 1996 240SX SE
Oh no amp, like I said I'm totally new to this. I was looking at the wrong article. Thanks for the links. I hope it is't anything too crazy. I'll give these a try. What I meant on the switch is that when you move the window switch as if to raise the window, the wiring after the switch shows power, but not when you lower it, but the window does not move in either direction. Thanks again
