Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Feb 26, 2004 5:07 am
You ask things like: when were all the shocks changed, when were upper links and tension rods last changed, when was the brake fluid last flushed, was the ac system serviced, was the receiver dryer replaced, when was the coolant replaced, when were plugs last changed ............this is a $4,000 area.Have the oxygen sensors been changed, has the fuel pump been changed, transmission mounts, motor mounts, water pump, thermostat, etc etc lots of normal maintenance items need change at 120k.
Were the plenum hoses and knock sensor/harness replaced a $1500 job.
From 70-to 123 k is ~~ 50,000 miles I would have expected at least $5,000 in out of pocket expenses 10 cents per mile]...tires, brakes, services, some repair work after the $1,000 @60k routine service............ask for paper work proof.
The point is you may be better off paying $6,000 for a well maintained unit than $4,000 for a car where nothing was done.
An owner that choses an independent transmission repair over the dealer [factory remanned unit] worries me.........as there can't be a $1,000 difference [if you negotiate].
