elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat Nov 27, 2004 6:22 am
Welcome to our humble little club.....
Sounds like you got a decent Q.. the 93 is probably one of the most desireable of all the 1st gens, besides the really early ones... I digress.
Anyway, something you must be apprised of... the chain guides... As we all konw the Q45 uses a timing chain.. The guides for the chains were made of plastic, and at higher mileages they often (will) break and cause the timing chain to flop around, and eventually skip a tooth on the cam sprocket.. That will cause valve/piston Pattycake, and since the engine is an interference engine, it will mean complete destruction of the engine, unless you are VERY VERY lucky, but in all honesty, your driving a time bomb...
However, it has been rumored that the 93s (especially late ones) have the updated guides (metal backed instead of plastic/nylon)... Not worth the change, its worth the $500 to have the front cover taken off to see/verify the guides are the newer kind..
Waiting will only delay the inevtiable.. Just ask Fred (palmerwmd), he's owned 4 Q45s and has had the guides go out on various engines 3 times.. the 90-93 VH45DE are getting very hard to find, as its hard to find a pristine example, low miles, with the guides changed or with low enough miles that the guides wont have failed...
We've seen failures as low as 60k, and others still running fine at 189k.... Jesda waited until 189k on his Q, the guides were completely torn to pieces and it could have been at any instant they failed. If they are broken, you must have the oil pan removed to get the little pieces out, as they can clog the oil pickup and cause starvation...
So sorry for the bad news...
For your other problem, 2 things we can do..... First you need to check the codes on your TCS control unit. It is located under the rear parcel shelf... Take out the trunk divider, and read the codes... attached is a picture of a flowchart that may help you.. But you need to check your codes to see whats going on... Heres how you do that....
The codes are stored only while the car is on.. As soon as you turn it off, it will delete the codes. So take the rear carpet thingy out, drive around until you can get it do the symptoms, then park the car, and count the number of blinks the LED on hte TCU contorl unit.. It will blink, say 18 times, and youll have Code 18... post the code and we'll go thorugh some diagnostic procedures...
It will blink the code, and then pause, and then go to the next code or repeat it...
