Pwnin Obrien »
https://forums.nicoclub.com/pwnin-obrien-u158474.html
Fri Apr 16, 2010 7:32 pm
Radio Shack sells some decent brightness blue LED's, I think you can pick up a 5mm for a few dollars. The resistance you need really depends on the LED (more specifically, the wavelength), Radio Shack used to display the specs for their LED's online but do not anymore. First you need to find out the value of the factory resistor on the security LED board using a multimeter. I would then call your local Radio Shack and ask them for the specs for the blue LED from the packaging (you need the drop voltage and the typical current). Then with those numbers you can figure out what resistance you would need and you can pick up the LED and the resistor at the same time. If you need help figuring out what resistance you need you can post up the LED specs and the factory resistor value and I can help you with the numbers.
You're probably thinking "this is pretty ridiculous, do I really need to do all of this?" Well, no, you don't absolutely have to. If you didn't use the right resistance you would likely overpower the LED and the LED would only last a few months. When I first did this mod I decided not to use the proper resistance because I was lazy and just didn't want to solder in a new resistor. My LED was REALLY bright but it only lasted about 6 months then it died. It didn't really matter because I had installed an aftermarket alarm that had its own blinking LED so I actually was going to disable the factory security LED anyhow. So you really should go through all this work so that the LED will last the life of the vehicle.
