driverdriver »
https://forums.nicoclub.com/driverdriver-u9137.html
Wed Nov 28, 2007 4:22 pm
Welcome to NICO!!!
For your HICAS light pull the code from the ECU and report what it says. There is a "sticky" for obtaining codes based on whatever year your J falls in in this forum.
The J needs to be warmed up before it starts running well, its not a start and drive car. Hesitation between gears is normal when starting out from a cold start.
Airbag light-if its blinking while your driving, pull the code from the ECU. It will narrow down causes.
