Hey hey... glad to see that people are coming alive. Being a business owner, I do have a few minutes to spare to do some of the work myself. It's kinda like a hobby, so I'm diggin this...
Ok.
1) I saw the link on your website (or was it here) that talks about a cooler from B&M. I'll go ahead and get that done first thing next year. Should I just drop the pan and do a drain/filter cleaning? Or go to a BG shop and get a flush with a machine? Or... even the "poor man's" flush?
2) Are there radiator flushes? Also, is it worth changing the thermostat and hoses while I'm doing this? I'm in FL, you know, and this next summer could be a hot one.
3) I like your suggestion, and will probably get it done that way. Is it easy DIY with OEM filters?
4) Can I get the BG from a local auto parts shop? And as for the cylinder wall issue? Well, it is what it is. And that's the only thing I can think of. I thought someone here had mentioned that BG is a "harsh" fuel additive, as are all fuel line cleaners, hence the recommendation to change the oil?
5) Thanks. How do the OEM bushings hold up? Should I go ahead and get them replaced with Urethane ones? Or there aren't any other choices? If you dig through
http://www.lexls.com, you'll see that the 1st gen LS400's has people selling "new" tougher bushings. Perhaps those same people can cook up a set for the Q?
6) How do I get into the doors? Is it on the FSM? Also, the reason I suspect the harness is because the windows switch doesn't work from the center console, but it works fine from the door. Does that make sense?
7) Now I'll have to wait for the brakes to wear out. And the way I drive, it doesn't wear out much actually.
8) No transmission malfunction light. I didn't check the full "shift" from 2-3 and 3-4. However, when I gun it, it's a bit of a harsh shift from L-2. Define "smooth". As smooth as my 1999 LS400? The Q45t that I passed up had a somewhat "harsh" L-2 shift. Kinda like dropping the clutch. Is that common?
