Newbie CA18ET Questions
popeyensweetp
Car: 1992 Stanza 1996 Maximum
Hey, and Thank you.
I have put the ca18et in my racing datsun 510, so far so good. I do not have the maf or coils? Does anyone have a picture of the correct ones? Can I swap with a different MAF or do I need the stock one. I plan to intercool and hope to get around 170 solid HP for the Chump car endurance racing series. Any and all suggestions are greatly appreciated.
Thanks,
Popeye
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
If you're running the stock ECU, use the stock MAF. If you're tuning and going for performance, get the N62 MAF off the Z32 and tune accordingly.
And you can either get stock coils or here's a thread on swapping to RB coils:
post6580889.html
popeyensweetp
Thank you very much, can or do you recommend a piggy back ecu ?
Thanks Pops
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
Nistune is fairly inexpensive and gives you full tunability rather than just "tricking" the ECU like the SAFC.
boost_boy
And is this a CA18ET or CA18DET? There is a difference between the two and I just want clarification on which one you are really referring to.
popeyensweetp
It's the ca18et, not the ca18det, it was in the 200 sx 1986 ish . I found this motor on craigslist for 150. bucks, The internals look factory perfect, the compression, perfect every cylinder. So i though it would be a great 510 motor for endurance racing, I would like to get close to 180,, 200,,, HP with intercooler and ,mild tuning.
The key word is endurance, I will put rev limiter on it for the other drivers on my team. Not sure if you have raced endurance, so far i have done the 12 hours Sebring,,,, 12 Hours Daytona,,, 12 Hours Miami Homestead. It is So much ^%*$&^%$#*&%^(*&,,,,,,,, FUN
And I do appreciate your help very much.
Will post pict, asap.
Pops.
Cams
Car: 1993 Nissan 200sx CA18(DET) RS13
2002 Mitsubishi Airtrek JDM 4G63T (wife)
2013 Scion FR-S
2016 Infiniti QX50
That would be very interesting to see. 12 hours of continuous racing sounds like a lot for the average production engine, but you would know better about it.
Do you go overkilling with your Radiator and oil cooler for this type of competitions?
float_6969
Whoa, I didn't catch the ET part. That's a whole different ball game. Standalone is your only option for that thing. Also, I'm pretty sure that had a distributor, didn't it? I think it was still electronic ignition though.
dash
Car: s13 ca18
check http://club-s12.org/retro4/ they have a dedicated ca18Et section
You should b able to find any info and your missing parts there.... as quite a few of the Et, converted/swapped to DEt
