We've mounted a large metal fan as a temporary fix until the fans arrive (next week). Power comes from a converter plugged into the cigarette lighter socket so we'll need to remember to turn it on every time we drive the car. Seems to extend the time traveled by about ten minutes before overheating.
I had bubbles in my coolant in my project car, due to a hole in the coolant overflow reservoir cap. The idle fluctuations on the 200sx, unlike my project car (AW11 MR2), don't go away after warming up. I do have to note, though, that the reservoir cap on the 200sx is a bit loose, and I really wouldn't be surprised if there is air in the coolant. I'll bleed it when I add more coolant in to achieve the optimum pH.
I'm new to turbos. I've read elsewhere that you need to warm up the car for a few minutes before driving and idle for a few minutes before shutting the engine. Is there anything else I need to be aware of?
I'll look into Mishimoto radiators if the car still overheats, and will keep an eye out for a NX2000 radiator.
CourtesyParts bookmarked.
Fortunately, the car doesn't show any other symptoms of the BHG, granted I'm not familiar enough with the car to tell if the engine has lost compression/power or not by driving it. It really does pull, though, faster than any other car I've driven. If that turns out to be the case... don't know what I would do. The SR20 seems to be a good engine, very popular from what I've seen. Not enough space on my parents' driveway to hold another project car, though.
Thanks for your help. I'm very grateful for it.
Edit:
More pics.
Rust/Bodywork
Crack on RR fender
Rust and scratches on RR fender
Rust on RR quarter
Rust on RL quarter
Rust on RL fender
Rot on RL fender
Rust in trunk gap (left)
Rust in trunk gap (right)
Rust in driver-side door arch
Rust in passenger-side door arch
Temporary Fan Fixture
Glove compartment with goodies
Bled the coolant and replaced the air intake filter today. Car still idles very rough below 1000RPM. Turbo might have some shaft play. Took a look under the car and was happy to see no signs of obvious rust, only poorly welded exhaust pipes that might be the source of the exhaust leak.
Noticed that the RPM fluctuates whenever I turn the steering wheel. Potential electrical problem?
