oldsilvia-s12 »
https://forums.nicoclub.com/oldsilvia-s12-u42286.html
Wed Sep 16, 2009 11:28 am
About a month ago I bought a early 1995 KA24DE (with the butterfly) swap that the hold owner was about to rebuild before swapping it in his 240sx.. that he wrecked. From the ex-owner the engine is in good condition with 120 000km (+-70k miles) and was just thinking that since the engine was out he should rebuilt it.
So I took off the valve cover, cams are immaculate, I compression tested it:180, 175, 175, 165.. good enough for 1-2 years in it stock formi guess? Because I wanna go KA-T in the near future and don't see the point of rebuilding it twice or to run lower compression pistons in N/A... so the longblock will stay the way he his.
I've ripped off the butterfly system and filled the holes with some JB weld, took off the exhaust recirculation manifold in the upper intake parts, I'm gonna plug that.. All I've read about KA is from KA-T or the KA-T section here so I guess that all the emission stuff and IACV and EGR can be removed from a N/A ka without issue. I'm also gonna need some serious help to plug back all the hoses and vaccum because I've buy the longblock with all the accessories already appart, so I've never work or seen a complete KA appart from some internet pics...
Plus most hoses have been cuted so I'm gonna have to make mine, so again I'll need ur help to figure out what plug where and stuff like that.
I'll be adding pictures of my progress tomorrow!
Right now my biggest concern is: I've read that i can get rid of all vacuum on the kind of mess bolted on the back of the head (the bracket with 2 solenoid and plenty of lines).. is that true? So I can just grind/cut out the line and leave the bracket with the two solenoid? Need to plug the solenoid vacuum ports?
Modified by oldsilvia-s12 at 1:03 AM 9/17/2009
