nismojunkie wrote:VIN: YV1FA874XJ2244835 Year: 1988 Make: Volvo Model: 740 Style/Body: 4 Door Sedan Engine: 2.3L I-4 EFI DOHC Tbo Country of Assembly: Sweden here si the info for the volvo, so i spose it is a t3.
T3
.42 compressor housing.48 turbine housingInternal wastegateJournal barrings.Oil and water cooled (earlier versions were oil only)
Just a guess Quote » someoen todl me you can check a turbo by blowing compressed air through the intake side of it and if you hear it spool up or whatever it is good. [/quote]Not true.
That test will tell you nothing as far as what condition the barrings are in.
Shaft play is where its at......if you can wiggle the impeller and hear a clunking noise then its bad.....real bad.
