altho im listing only the parts that i think will get this thing running, my goal is 350dd/road coarse hp, WITHOUT HAVING TO BE REDUNDANT with the whole upgrading parts to support that need, anyway, let me know if im missing anything that will make turning that key a nightmare, or if you have any part suggestions
i noticed my clutch was wack so first off,
NISMO SLAVE CLYLINDER
NISMO SS CLUTCH LINE- any alternatives?
REDTOP MOTOR/TRANS/ECU/UNCUT HARNESS SET- 175psi i hope? prolly lucky to get a 155
IGNITER- 95 q45?
SPARK PLUGS- BKR6EIX heat range 6 for now rite?
OEM OIL PUMP KIT- any seals that i need to order also?
OEM WATER PUMP-
STANCE WP PULLEY- i like to revmatch
GRIFFIN RADIATOR- custom mounts, any1 running a griffin? i see all koyos
HEATER HOSES-
BELT SET-
AVID RACING MM/TRANS MOUNTS- could i hold off on these?
GREDDY OIL PAN/FILTER RELOCATION KIT-
APEXI GT SPEC DP-
APEXI NOIR EXHAUST-anyone runnin this? is it actually quiet?
ISIS INTERCOOLER WITH ALL PIPING- i chose this cuz its cheap, but will i end up buying 2 intercoolers when i reach my hp goal?
BATT RELO KIT-
TIAL ALPHA Q(nice name) BOV(bong)- will i have fitment issues with this? i will need to use a weak spring for low boost right?
JWT Z33 CLUTCH/FLYWHEEL COMBO- anyone else but codyace do this? does it really work?(codyace-do i use the JWT pressure plate? or source an sr pplate)
zeropost?cmd=newtopic&id=17#
is there anything i could cut from that list to make this happen sooner? or will it contradict my do it once do it right mentality
thanks
