Newb Setup Question
Redtop Man
Hate to be the noob to ask the anoying question... but what do you think this setup would see hp wise?
SR20DET RedtopGreddy V-SPL FMICGreddy RS BOVGreddy DPRSR GT2 ExhaustSome type of piggybacy fuel control, probably S-AFCProfec BEnthalpy Tune ECUT28 Turbo (for now)
Upped boost to maybe 12-15PSI
Then some other stuff not realted to HP...
Would i be expecting too much to think maybe 300WHP? If so what would you estimate Id see in hp numbers. i noticed on another topic some guys were seeing 250-300WHP with minimal mods, so i was just curious and bored.
vutony
u need at least 550cc injecotrs and z32 maf to reach 300hp
SpeedRacer1
Car: 1990 240SX, G35
In real whp you could possibly get about 245-255 whp. I dont see why you would need an SAFC or piggyback unit if you are buying a chipped ECU.
Redtop Man
SpeedRacer1 wrote:In real whp you could possibly get about 245-255 whp. I dont see why you would need an SAFC or piggyback unit if you are buying a chipped ECU.
I dunno either, just figured it would be better for tuning just right... and Vutony, i figured it was assumed so i didnt say anything about it... so really that low of a number? how is it that some people on the numbers/dyno/ 1/4 thread or whatever its called have only a few simple mods (intercooler, t28 turbo and upped boost) and make like 250whp+...?
Example: NoStickers post
Redtop w/ Stock t2514.7psiGreddy RSPL fmicApexi Gt Spec Exhaust3" downpipe and test pipeWalbro fuel pump250hp & 257ft lbs
basic easy mods and 250hp, and ill have more mods for power
thechinamannN
Car: 97 bmw 528i/92 240sx
basically the setup nostickers is possible makin 250hp, but i assure your setup will not make 300hp without a little more upgrading. this thread should help you out zerothread?id=59344
Redtop Man
well going by that and what i know i have planned i should see 350whp range within a few months, if not more... hell i might even decide to go all out and build the engine before adding bolt ons. go ahead and get me a good base to build on, then add up the power
