isaiahrsoccer16 wrote:Thanks for the info guys. yes all labor except fabrication/bodywork will be done by me. so roughly 10,000 assuming i already have the car?
10 grand NOT including the cost of the car.... I will show you my list of the parts I've composed that is needed for the swap and rough estimate. Yours will be different depending how in depth you are willing to go in your project. Keep in mind that I use QUALITY parts. For those who say I paid too much or don't need this or that....F*ck off. I know what I'm buying. Thank you.
R32 RB26 Front Clip ~ $4500 Shipped "Average cost w/o front clip, subtract 1g"
RB25DET Transmission ~ $1000 Shipped "MAKE SURE YOU DON'T BUY THE NON TURBO RB25 TRANS, THEY ALMOST LOOK THE SAME"
RB25 SPEC Clutch Stage 2+ w/ steel flywheel ~ $650
Syko RB Motor mounts w/o RB25 Down Pipe ~ $410
RB25DET Crossmember ~ $250 Shipped
RB25 Engine Mount Brackets "goes between the engine block and Syko mounts" $150 shipped from Europe
Tial 50mm BOV w/ pressure spring and V-band ~ $260
Custom Steel Driveshaft ~ $400
Custom inter-cooler w/ piping ~ $800
McKinney's Touge DP ~ $550
HKS High Power Exhaust "Anything with 3"in exhaust will work" ~ $550
High Flow Cat ~ $250
Aeromotive In-Line Fuel Pump ~ $150
Koyo Radiator for ka24de "Inlet and outlet fittings are similar to RB radiators ~ $300
Flex-a-lite Dual Slimline Radiator Fans Pull type ~ $400
Front Timing Belt w/ Tensioner, Ideler, etc ~ $150
Sikky Sway Bar ~ $300
Rb26 OEM Gasket Kit ~ $150
ACL Race Bearings ~ $200
Rb26 OEM Pistion Ring Set ~ $100
ARP Head Studs ~ $260
N1 Water Pump ~ $200
N1 Oil Pump ~ $200
RB25 New Crank Pully ~ $100
Oil Crank Collar ~ $100
Oil Restrictors ~ $20
Go ahead and add how much this all costs. Mind you that its not including simple stuff like:
Spark Plugs
Thermostat
Fuel Filter
Radiator Hoses
Custom Heater hoses
Clutch Input pilot bushing
Oil Pressure Sensor "Must replace as these commonly go out"
Replacing worn/broken parts if need be, such as:
Oxygen sensor
Water Temp sensor
Intake Temp sensor
Cracked Vacuum Hoses
Igniters
Coil Packs
PCV vlave and hoses
P/S belt
Alternator belt
Clutch Slave cylinder
Clutch Pivot Ball
IAC Valve
Valve cover grommets
CAS Sensor
Now with most of the preventive maintenance stuff out of the way. It's hard to add some upgraded parts to your build without going over 10 grand. Imagine buying other stuff for the car such as wheels, coilovers, body kit, paint, suspension upgrades, baller a** Tomei LSD, etc.
You don't have to buy the Syko motor mounts. They require you use the R33 RB25 front engine crossmember to work with their mounts. You also NEED the engine mount brackets to go with it. Some people say that using the R33 crossmember is a lot stronger than using the stock member that other companies offer. It will be cheaper to go else where besides Syko mounts. I just like how the Syko mounts are closely designed to oem style and fitment.
Another cheap option is to use the Z32 transmission instead of the RB25. Price range for the Z32 transmission can go around $100-$500 bucks. Most of the RB Custom mounts are for use with the Rb25 trans. The Z32 trans is shorter on the tailshaft end. And it uses an external shift linkage. You can't order a pre-fabbed driveshaft from the DriveShaftShop.com cuz thats the length for the RB25 trans. You will need to measure up the length for the Z32. Also you will need to custom fab the rear transmission mount for it too. The RB25 just uses the skyline rear trans mount or you can use one off an automatic 240. The Z32 will need the front bellhousing swapped from the RB25 or Rb26 that has already been converted from pull to push. "Link shown below"
my-pull-to-push-coversion-how-to-t283159.html
The only RB26 skyline that has the push type set up was the early model R32 GTR's with build date before 08/91. The rest are pull type then after.
The final and last thing for using the Z32 trans is that the shifter location may be off by 4 inches towards the back of the vehicle depending on what motor mounts you use. I could be wrong. But anyways, I've seen guys cut holes in their shifter tunnel to clear the shifter. Or you can modify the z32 shift linkage + bracket and shorten it by a few inches to center the shifter and line it up to the hole. Or you can buy one that is pre-made and sold in FRSport.com. It's expensive and I've heard many complain that the bracket flexes during hard use and cause people to miss shift or grind gears. With buying the Z32 trans, its cheap and has the same internals as the RB25. The laber and extra small cost it takes to make it work might not be worth it to some. Unless you got a heavy foot that blows transmissions left and right, this is your only cheap solution. But in the end if you want easy. Just buy the RB25 trans for plug and play.
Sometime this week I'll post some of the web links I used to reference my build from. I have a lot of them bookmarked but I'll sort through them and post it on here.
