Oh, and be sure to post up some pics of the build. Hell, even start a build thread in General. I'd love to add a cool build like this to the build thread list.agent4573 wrote:I'm doing a sandrail build and picked up a Z32 N/A motor for the project. It came with what appears to be every sensor needed, cutoff exhaust right behind the O2 sensors, and the ECU. I know I'm missing a few parts to get it turning over, but thought I would post here before I put up a wanted ad. I'll post pictures tonight when I get home from work, but for now I know that I need an alternator and all mounting hardware, a water pump pulley, and intakes/MAFs.
I'm going to browse local junkyards for the alternator and mounting hardware, but is there anyone that makes aftermarket mounts for the alternator? Not to my knowledge. As far as where to get it, the classifieds section has a ton of part outs. I'd check there if junkyards leave you empty handed. Do the water pump pulley and alternator share the same belt so that the alternator acts as the tensioner for the water pump or do I need to get a separate tensioner for the water pump belt? They share the same belt.
The intakes appear to have a ~1.5 inch hole on the top of each side. I have a black tube that appears to be a cross-over tube for the intakes. I was just wondering if I needed that or if I can get rid of it and block off the holes. There also appears to be a ~1 inch hole on the bottom side of each intake. I have no idea what those are for, any help would be nice. That's the balance tube. It equalizes pressure in the opposite sides of the intake manifold. Also runs some vacuum systems. You'd have to look at the FSM to see exactly what it runs. I wouldn't delete it.
Since I have no MAF, its a coin flip right now on running a single or dual filter setup. Is there anyone that sells just an intake Y pipe that I can bolt a single MAF onto? The rest of the intake will be custom, I just need this one piece. Otherwise I guess I'll have to go with a dual setup. If you don't have a MAF, You'll need at least 12 inches of piping in between the MAF and the TB's. If I were you, since obviously you'd want to save space on a sandrail, I'd look into a MAP sensor conversion.
For mounting, can anyone post a picture of where the motor mounts bolt up to? I'm going to be solid mounting this in the frame, but I want use the mount locations if possible and there are a few holes tapped into the side of the block. Just want to get the right one. Don't really have a picture, but they go under the exhaust manifolds. Check the FSM for better IPB's.
Thanks, and again, I'll drag it out from under the workbench tonight and get pictures up so you can pick out what I'm missing.We'll be standing by.
agent4573 wrote:MAP conversion sounds like the best option, but before I start reading up on it, can you just answer this, can you run a MAP conversion on a stock or easily modified stock ECU? As long as a MAP conversion doesn't require a stand alone I'm down for giving it a shot. Eventually I'll be doing a standalone, but don't have the cash to drop on it yet.
