mentordrift wrote:okay, I have been doing some reading on the factory service manual, and I need to get some feed back about my new ideas brewing in my head.If I am looking at this picture correctly, it looks like Plug e201 plugs into e17. Which from what I would assume would plug into e216 that is the speed sensor. Theorhetically, I could run wires from e216 to e17/e201, and then the speedometer would work, because the ECU would then be getting a signal from the speed sensor?I went outside and checked all of my wires that are currently there, and I have wires to the 4 plugs , but only one of them (the reverse lights) has anything running to the transmission.
you're on the right track. i THINK the reverse lights and the speed sensor share the e201 plug under the fuse box (verify in the FSM. that is the best approach). I know the e201 plug has 8 pins, and pins 3 and 7 are the speedo.
in order for the ECU to get the speed sensor reading (assuming you haven't touched the body harness) on the s14 chassis, it goes through the speedometer first. once it hits the speedometer, it splits off and goes to the F3 plug, which you then need to wire from the F3 to your ECU.
first, i'd get the speedometer working, then worry about the ECU. so run the two wires from the speed sensor to that e201 plug. if you do that correctly, that is the only thing keeping your speedometer from working. after you get that working, check your F3 plug and see if you have a wire going from there to the speed pin on the ECU.
also... its probably not possible that your speed sensor isn't there. if it's missing there will be a hole in the trans that leaks fluid. i'm 99% sure its just not plugged in.
