newb here ? about bluebird sr20det
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
swapnissan.com
hey whats up all. im new, and still figuring out how to navigate the forum. hopefully askin a question wont upset anyone.
question i had is what is the difference in a bluebird sr20det motor, and a silvia s13 red top sr20det? i know the transmissions are different, but the motor itself? we know all about the silvia motors, but i was sorta perplexed with the bluebird motor. ive tried to search everywhere, but to no avail.
thanks for the help in advance, and hope to be posting often!
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
different head casting, different block casting, different accecory mountings, different motor mounts, Intake manifold inlet points in the opposite direction, uses different clutch and flywheel, Uses distributer instead of direct coil iginition, different and un-interchangeble ECU's, different wire harnesses, etc...
Less in common than one would think...
swapnissan.com
wow, well thanks for the information. ill be sure to keep that in mind.
Onizuka
Its lots of odds and ends stuff that is interchangeble, like the oil filter. Engine internals can be swaped around too.
http://www.nissaninfiniticlub....59345
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
