New z32 owner
PerryG
Car: 1993 Nissan 300zx na
i just bought my first 1993 nissan 300zx na today and after searching i still cant find common problems for them. if someone could let me know the common problems with this car please let me know. (to start with, the one i bought has a misfire and i can smell fuel). THANKS!
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
In this forum there's a sticky called "Everything you need to know about the Z32", you should read the whole thing (its not that long). It goes over exactly what you want to know.
In short though, if you have stock fuel injectors (which you probably do) they are probably the source of your misfire and fuel smell. Another common problem is corrosion on the electrical connectors inside the engine bay. If you pull off a connector and the pins have green stuff on them, that's corrosion.
But really you should read that whole sticky.
And welcome to NICO! good luck with your Z
t.mcginley.jr
1966 Ford Mustang
and here's the link if you can't find it for some reason:
everything-you-need-to-know-about-the-z32-t508377.html
PerryG
Thanks alot!
