OOOOoooo, someone WANTING to dive under the hood of his Z!
A fairly beefy but doable project is to change out your spark plug coil pack and injector connectors. You can get the two connector kits at the normal Z32 vendors and if you can cut/splice/solder/heat shrink wiring, your Z will most likely respond with smoother idle and takeoff from the loss of the corrosion that almost always will be there at the injectors, and make your spark plug changes easier losing the brittle OEM connections for some new ones. Takes about a half to full day depending on your skill and time available, and requires removing a few of the top engine pieces like the balance tube, throttle cover and linkage cables, and a few other similarly minor items as you go about the work. Do take the time to route you new wiring for better avoidance of heat, and be sure to lengthen the #5 wire so it isn't going over the intake runner, but around from the inside like the others...
Cleaning/replacing corroded connectors is a must for our cars, as Nissan did us no favors in that department until 1996.
Another good maintenance project is to redo your connectors and wiring for the two CTS sensors, and depending on the age of your Z, replace both sensors.
Another good project is to remove the PTU from the front of the engine (best done when doing the CTS work FYI) and loosen your radiator enough to slip the harness through and into the front area, and remounting it down on the DS frame rail. Cleans things up in the front of the engine, and puts the PTU in a much better environment away from all of the engine heat. Be SURE to open BOTH connectors and clean them well, as most likely they are green with corrosion as well.
More good projects can be found on your Idle Air Control Valve on the back DS of the engine, it has two connectors that most likely are unhappy and can cause you idle issues, and warm up issues.
Have fun!
