New z32 owner idle/fuel problem
method2madness
Car: '93 Maxima - Sold
'00 Maxima - Sold
'90 300zx - Daily
I have owned my 1990 5 speed z32 for a couple of weeks now. I got the car with one of the injectors shot so it was running on 5 cylinders. To make things worst regular gas was put in to the car (accidentally) and made the car run worse. All the injectors failed, spark plugs fouled, etc. So I pulled the plenum and just decided to changed them all to the new style injectors. I bought the Injector Adapter Kit from Z1motorsports to do the new style injectors to old style fuel rails and replaced the old plugs with platinum ones (copper ones were in before). After putting everything back together the car still doesnt run right. When i rev the car its a lil sluggish and sounds like one of the injectors are shot but i checked them and all the ohms are good (11.2 - 11.4). I checked the injector connections, coilpacks, changed the fuel regulators, fuel filters, reset the ecu, and still the car runs ruff. Does anyone have any idea whats going on, something I should check???
Phan
Car: 2004 350z Roadster ~ Pearl White
1993 300zx Conv. ~ Pearl White
recheck the coil pack 1 by 1. Other then that you might have a vacuum leak or install something wrong.
method2madness
'00 Maxima - Sold
'90 300zx - Daily
Phan wrote:recheck the coil pack 1 by 1. Other then that you might have a vacuum leak or install something wrong.
After I changed the plugs and injector the coil pack for cylinder 1 burned out so I checked the others and they were fine HOWEVER I do remember my friend saying something about checking for a vacuum leak because I noticed that when the car is idling and I hold the brake for a short period or just keep pumping the brake the car the rpms die down to under 1000 and then shuts off. Which vacuum line do you think it is?
Phan
lol there's so many vacuum lines in these cars. I suggest you start checking them one by one. it can also be a pinched O-rings.
method2madness
'00 Maxima - Sold
'90 300zx - Daily
True, I'll do that lol. and if i had a pinched o-ring would i simply be able to tell by fuel around the injectors and connectors?
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Welcome to Nico!
How did you determine the coil pack was dead? Did you swap it to another cylinder? Have you performed a PTU test?
Click -> dead-cylinder-can-t-figure-out-why-read ... 64452.html
method2madness
'00 Maxima - Sold
'90 300zx - Daily
Ziggy1621 wrote:Welcome to Nico!
the coil pack was corroded and beginning to melt after changing the plugs the 1st time and I swapped it out with a spare. I did check the PTU, tried a different one but the was no difference.
Ziggy1621
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Are you getting any ECU codes? Are all of the injectors firing? You can use the screwdriver test where you put a screwdriver on the injector and the other end up to your ear
method2madness
'00 Maxima - Sold
'90 300zx - Daily
Ziggy1621 wrote:Are you getting any ECU codes? Are all of the injectors firing? You can use the screwdriver test where you put a screwdriver on the injector and the other end up to your ear
I believe they are all firing but I'll check again tomorrow. I need to also check my vacuum lines. I got the car with the egr and water deleted.
Exia
Car: 1993 Nissan 300zx TT HICAS
Make sure you have the exact plug's installed, They are suppose to be NGK PFR6B-11B
Also don't forget the 6 P's http://www.twinturbo.net/nissan/300zx/f ... ncegt.html
Ziggy1621
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Exia wrote:Make sure you have the exact plug's installed, They are suppose to be NGK PFR6B-11B
Wrong plugs may hold back peak performance, but that shouldn't produce a miss.
Exia
Accually it, can but it also has some other variables to that as well.. like the gap for instance.. I was having a simular problem, with my TT found out the guy had auto lites and gap was way off.
and sorry I assumed your's was a TT if your's is a NA you need these plugs NA stock = PFR6B-11 gapped to 0.044" (1.1mm)
But recommend you follow the link I gave prior, it will answer alot of your questions.
method2madness
'00 Maxima - Sold
'90 300zx - Daily
The plugs that I have currently in the car are NGK Iridiums IX and not platinums. Do they need to be gap'd??
Ziggy1621
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Not a bad idea, but wouldn't be my first test. Did you check the injectors yet?
