evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Feb 01, 2012 1:19 pm
hmmm, I've never seen a foam z31 spoiler but maybe they tried it for a year or 2? all the others are hard plastic/fiberglass
I'm a fan of the vg30et, the car as it is is actually very well ballanced, the center of gravity is just forward of the shift knob, with driver it should be dang near center of the car
the vg30et stock is 190 hp (crank) with a boost controller and an itnercooler 300 whp is achievable, thats nearly double stock for very little cost or effort!
beyond that, your are looking at upgrading the turbo, injectors, ecu, maf (assuming you continue running an ecu that requires a maf), yes north of 400 whp can be had on stock internals but these are cast pistons and at some point become the weak link
the later "W" series engine are more desirable, they use floating wristpins, and have some other minor improvements, the stock turbo inlet and downpipe are both points of restriction, satan manifolds or similar will allow you to relocate the turbo and overcome those issues
as for other engines, well, if you like GM the LS is popular in all manner of cars these days and fits nicely beneath the stock hood of most cars, I'm sure it's been done, but it's cheaper to modify the vg
