New Z31 owner from the UK
A home for 1983–1989 300ZX owners!
just-james
Car: 1983 Z31
2000 200sx S14a
Hi All
Just bought an n/a Auto Z31 and having a bit of an issue!
when the car is in Gears 1, 2 or in park or neutral it will rev fine all the way to the limiter, however when the car is in D it will stop at 3000 revs and stay there permanently..
Anyone got any ideas?
Thanks
James
Welcome aboard!
So, do you mean when you're driving with the gear selector in D, it won't exceed 3k rpms?
just-james
Car: 1983 Z31
2000 200sx S14a
yeah thats the issue..
Most likely issue: The throttle position sensor. Sometimes, if they get wet, or soaked with oil, they'll act up. It's on the throttle body just behind the rubber boot that connects the air flow meter.
AcadianaSportsCars
Car: 1986 300ZX Turbo, 1989 VW Cabriolet
In addition you may want to check out the MAF sensor as well.
The Factory Service Manual for your car will be quite helpful in showing you the proper testing procedures! I think they are available here on the forum.
Congratulations on your new Z31!
Return to “300ZX (Z31) Forum”
