evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Mar 09, 2011 11:55 am
to test the chts, with the car warmed up and idling, unplug it, it should run a lot worse and ro die, if no change is noticed you have a bad chts
are you sure the car is idling on all 6 cylinders? you cna unplug one spark plug at a time and see fi the idle changes, if one cylinder does nto change it's nto firing forwhatever reason, bad plug, wire, valve, ring etc
and exhaust manifold leak will either sound like lifter clatter and or just be really loud, the bigger the leak the more it can hurt performance btu it shoudn't cause a lopey idle
