nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Tue Sep 02, 2014 7:28 pm
Do you feel it in the seat? If so, swap the rear tires tire to the front and vice versa. If the problem still in the seat, you ruled out tires and wheels. Also when you have the rear end in the air, grab the wheel at 12 and 6 oclock position, try and move the wheel. If you have any play, bad wheel bearing.
If the problem is now in the steering wheel, issue with either tire or wheel. Take it to a shop and have them balance the tire. They may even see if the wheel has a bend or something.
How is the transmission mount?
