Update!
I got the Z1 conversion kit for the 95+ injectors, and its awesome! I bought new lower plenum to fuel rail seals, new orings, 95+ 370cc pintle-less injectors, and the 95+ injector connectors. During this time I also looked for cracked wire loom on the harness and covered broken areas back up with electrical tape. I also found some disconnected wires for the det sensor, so I soldered those back together.
Rerouted the turbo coolant lines and some vacuum lines according to a guide found on TT.net which was a huge help! Definitely a must for anyone doing their first plenum pull.
Here are the new injectors, inside of the fuel rail seats were cleaned religiously, you can see the new caps and adapters for the old style fuel rail
Also replaced was all the fuel line for the rail, the upper part of the rail, the fuel filter, the rubber lines running to the filter and the rubber return lines
Here are the injectors in their new seats, the new cap screws are allen head instead of phillip head screws.
Also included in the kit is an oring grease and that makes everything go together easily and successful.
Fuel rail installed, look how good those new injectors look!
Picture of the soldering, I used heatshrink after soldering them together and then covered it in black electrical tape
Here is the plenum all buttoned up and ready to go!
The car runs like a swiss watch now. Runs absolutely amazing. Fires up immediately, it is very responsive and healthy. I really couldnt ask for more. I smogged the car and registered it, ending its 8 years of non-op! She passed with flying colors.
Here is a pic as she sits now, with my SSR integral A2s on! (they are plasti dipped bronze/brown, but will soon be anthracite black) In the backround is my 92 NA (Which I have sold to my younger brother and he is enjoying it)
I have a few small things left to do, I'm going to replace the radiator lines with brand new ones, and my driveline makes a rattle in first/second gear under 2500rpm when under a load, so I think my center support bearing may be on its way out. I'm looking into the Z1 Platinum 1 piece driveshaft but I dont want any vibration issues at speed, anyone have any first hand experience with those?
Edit: Checked the driveline out today, seems the center support bolts were overlooked when I reinstalled the driveline, they were still finger tight and were loose. I wrenched that down and now its golden! Phew!
Next up is installing my exhaust, pop charger and the full Powertrix suspension!
