NewfoundlandDude »
https://forums.nicoclub.com/newfoundlanddude-u64486.html
Mon Jul 23, 2007 12:10 am
I went to Napa and bought two gaskets for the cat (Front and back) because the Nissan metal ones were producing a tiny leak from when I got all 4 cat bolts removed and replaced. Warpspeed provided two new crush gaskets, and this is what was used on the headers. I replaced the broked studs in the header (4 of 5), and now have all 3 on the rear header and 4 of 5 in the front header (I'm going to have to get a garage to get at the 5th). All heat shields have been removed for the most part, so I'd say it is a clearance problem. There is an violent vibration on sharp acceleration, which tells me that due to flex on acceleration, something is not getting the clearance it needs.
Your pry and tighten idea is probably then best advice that I've gotten so far (I've gotten some on the other forum). I know that the audio I provided was REALLY CRAPPY, but it was all that I could do at the time. I think that the crappy Warpspeed hangar that they provide which is not threaded and just sits in the front rubber hangar (In front of the cat) is probably causing a problem as well. I'm going to try and thread it to try and stiffen up the damn thing too. The stock pipe was supported much more than the Warpspeed pipe, I can think of at least two places that the Warpspeed pipe can be supported better. #1 here is hidden on the picture, but was bolted to a bracket on the stock pipe, and #2 which was a welded flange is now just that non-threaded bolt on thing. I''m not sure what #3 is, but I'm sure that the cat could be supported a little better too. A rear rubber hangar (Near the resonator or B pipe or whatever) I think is stretched, or the weld to the pipe is breaking, because I can hear a faint vibration back there a bit too. I took a closer look after I posted this, so this is where all of my rambling is coming from.
If you can think of any other common install problems, please let me know .
Thanks.....
