New Window Tint
ZMARKUS
Car: 1999 Infiniti Q45T
2002 Infiniti Q45
Got my old shot tint removed and had new tint applied. The rear window tint could not be removed without some damage to the defroster lines and from what I hear they are somewhat of a receiver for the factory keyless remote. Well, my remote is somewhat useless now and I just purchased a new facory keyless remote a month ago . I assume my best now is to have installed an aftermarket keyless remote that does what the factory did. Am I right in this presumption.
qship96
Car: 1996 Infiniti Q45
Easier and cheaper to re-engineer the current antenna- look in factory service manual and identify the proper connector that leads to the keyless remote system antenna and configure a replacement antenna- maybe something as simple as a piece of wire extended along the edge of rear deck to pick up signal from remote transmitter? This will take a few hours and very little cash to play around with to come up with a viable solution.
Q451990
I believe there are defroster repair kits as well... did you already have the replacement tint installed? (if so, you probably can't repair it using that kit)
Heath
ZMARKUS
2002 Infiniti Q45
Q451990 wrote:I believe there are defroster repair kits as well... did you already have the replacement tint installed? (if so, you probably can't repair it using that kit)
Heath
Yeah I've had it installed already. I was willing to sacrifice some defroster ability to get rid of that hellish tint. Didn't quite see that keyless issue coming, but wasn't to surprised because I read another guy had a similiar experience prior to my tint job. I just hoped my rear window damage would be minimal.
ZMARKUS
2002 Infiniti Q45
qship96 wrote:Easier and cheaper to re-engineer the current antenna- look in factory service manual and identify the proper connector that leads to the keyless remote system antenna and configure a replacement antenna- maybe something as simple as a piece of wire extended along the edge of rear deck to pick up signal from remote transmitter? This will take a few hours and very little cash to play around with to come up with a viable solution.
Hey man that's a sweet quick fix, but is it actually a possibility? Now when you say factory service manual, your not speaking of the owners manual are ya? I'd be surprised if that valuable info is in there.
Q451990
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
Did the installer use steam to remove the rear window tint?
frenetic
Car: 1993 240sx Coupe
jltibbs wrote:Did the installer use steam to remove the rear window tint?
Many use razor blades to start the peeling. Depends how old the tint is. Sounds like his had been on there for a long time if there was damage to his defroster...
NightRiderQ45
Car: 1998 Infiniti Q45
totaljett wrote: Yeah I've had it installed already. I was willing to sacrifice some defroster ability to get rid of that hellish tint. Didn't quite see that keyless issue coming, but wasn't to surprised because I read another guy had a similiar experience prior to my tint job. I just hoped my rear window damage would be minimal.
Yeah, there shouldn't be damage to those lines!! I've had tint removed on my car with no damage. They messed up and sold that lie to you. I would demand that they pay the price for their screw up. It would be hard in your case since you left their location believing the lie they sold you...
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
NightRiderQ45 wrote:Yeah, there shouldn't be damage to those lines!! I've had tint removed on my car with no damage. They messed up and sold that lie to you. I would demand that they pay the price for their screw up. It would be hard in your case since you left their location believing the lie they sold you...
Most shops don't guarantee (in the fine print) no damage to the defroster lines - removal quality is contingent upon installation quality.
tfvesquire
Car: 1998 Q45
Sorry to hear about your problem with the tint removal. I had the exact same problem removing the old crappy PURPLE tint on the rear window. I spent three weekends carefully removing the tint with a tint removal kit (didn't work) hairdryer (barely worked) 3M adhesive removal spray (at $25.00 per can) and then razor blade and small straight edge carefully cutting the tint along each line and carefully removing the material in between each line. I even left the tint on the defroster and keyless lines instead of trying to carefully peel them off. I still had no defroster, limited range on the keyless antennae (2-4 feet)and limited radio reception (FYI: there is also an FM antennae line in the rear window). At least you still have your defroster working.
I ended up having to find a good replacement rear glass at the junkyard and replaced the entire rear window so I could finally see out the back window on rainy/snowing nights, use my keyless as I was walking up to the car and get all my FM reception back.
I wish I could tell you there was a quick fix, but unless they are able to carefully remove just the tint that covers your keyless antennae (see the FSM) and fix it with a grid line repair kit, you may be SOL unless you go aftermarket alarm.
Good luck with all that. After the first weekend I wanted to track down the prior owner and beat the sh*t out of them for putting that cheap crap on the window.
I feel your pain.
Ted
qship96
Why a cheapie tint job really COSTS more than the top quality non-dyed window film in the long run. A top quality film wont change colors, delaminate, or need to be stripped off the windows, whereas the cheapie junk is lucky to last a few years, and often destroys the grids in rear window as many are finding out. Classic mistake of people confusing the price of something with the true cost.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
That is a sure sign one is in a messed up shop.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
this wasn't normal, unless this shop is your high school buddy or something I'd go back and tell them they screwed up and get them to fix it for you.
NightRiderQ45
BadQ45t wrote:this wasn't normal, unless this shop is your high school buddy or something I'd go back and tell them they screwed up and get them to fix it for you.
Exactly. That isn't normal at all but he doesn't have a leg to stand on at this point because he left the shop and believed the lie the shop sold him. I just had my 30% tint taken off two months ago(with no issues) and put 5% on.
qship96
5% ???? Is that legal in your state???? If not, plan on getting a inspection order ticket requiring you to remove it- cops now carry light meters to measure tint level, and if you fail state standards.......
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Unfortunately visual light rejection has little to do with infrared wavelength rejection which is where all the heat is.
Hüper Optik Stark 30 transmits 30% of visual but blocks 90% of infra red. Result is the vehicle stays cooler in the sun and the driver can still see out at night.
NightRiderQ45
qship96 wrote:5% ???? Is that legal in your state???? If not, plan on getting a inspection order ticket requiring you to remove it- cops now carry light meters to measure tint level, and if you fail state standards.......
No it's not legal, but the cops here don't care. That's why I snatched my tint off and put that on. Back home, I would have been pulled over as soon as I left the tint shop. I love the tint but I will see how well it actually works once it gets hot here this summer. Plus I have a nice Double Din cd/dvd player that I want to keep people from seeing.
Oh and I have no trouble seeing out at night too.
ZMARKUS
2002 Infiniti Q45
Yep steamed was used but claimed the previous type of installation and age of tint made it impossible for him to avoid any damage.
ZMARKUS
2002 Infiniti Q45
tfvesquire wrote:Sorry to hear about your problem with the tint removal. I had the exact same problem removing the old crappy PURPLE tint on the rear window. I spent three weekends carefully removing the tint with a tint removal kit (didn't work) hairdryer (barely worked) 3M adhesive removal spray (at $25.00 per can) and then razor blade and small straight edge carefully cutting the tint along each line and carefully removing the material in between each line. I even left the tint on the defroster and keyless lines instead of trying to carefully peel them off. I still had no defroster, limited range on the keyless antennae (2-4 feet)and limited radio reception (FYI: there is also an FM antennae line in the rear window). At least you still have your defroster working.
I feel your pain.
Ted
Yeah my tint was purple as well and 2-4 feet is the keyless capability as well. Radio is fine though but I don't know capability of defroster yet. Prior to removing my tint he explained the possibility of this issue and even pointed out on my defroster where some lines were already broken. This was prior to removal and it makes since because I keyless always had dead spots before all of this. Nothing like my Lincoln Ls that worked through doors, million miles away and so on. The Q never had that strenght even after my new OEM keyless remote purchase, so some little damage always existed. It's just terrible now.
NightRiderQ45
totaljett wrote: Yeah my tint was purple as well and 2-4 feet is the keyless capability as well. Radio is fine though but I don't know capability of defroster yet. Prior to removing my tint he explained the possibility of this issue and even pointed out on my defroster where some lines were already broken. This was prior to removal and it makes since because I keyless always had dead spots before all of this. Nothing like my Lincoln Ls that worked through doors, million miles away and so on. The Q never had that strenght even after my new OEM keyless remote purchase, so some little damage always existed. It's just terrible now.
I don't get it; so you already knew that damages could make it worst, why complain now since they told you this prior to the install? I take back my previous statement that I made against the installer.
ZMARKUS
2002 Infiniti Q45
NightRiderQ45 wrote:I don't get it; so you already knew that damages could make it worst, why complain now since they told you this prior to the install? I take back my previous statement that I made against the installer.
Well, I never had a complaint towards the installer. Just pointing out why I'm in need of an aftermarket keyless system. The unfortunate circumstances were explained in case someone knew of a magical alternative other than purchasing a keyless system.
NightRiderQ45
totaljett wrote:Well, I never had a complaint towards the installer. Just pointing out why I'm in need of an aftermarket keyless system. The unfortunate circumstances were explained in case someone knew of a magical alternative other than purchasing a keyless system.
Gotcha.
