Exar-Kun wrote:He may be able to bring it into spec, but I doubt it.
If the Zeal coilover has a way to adjust the scrub radious, that would really be impressive.
I don't actually know if the Zeals have it, but alot of the JDM coilovers I see do have it. Thats what the slotted hole on the bottom bracket is for, most people think its for camber which would just be redundant since any good coil comes with camber plates.
Exar-Kun wrote:Also, ideal frame height is refering to how low the car can be dropped without adversly affecting suspension travell, camber gain, and the voerall geometry. GRM had a nice article regarding it earlier in the year, with a small quip by David Visard(sp?)..
Err... I don't know if I have that one... but I believe I've seen it. Personally I run max low KTS coilovers (tucking tread on ST115 in 235/40) and I will Never raise my car, I love the way it feels and looks. It could handle .1 of a G worse than a higher car and it bumpsteers (no Outters) but I still like it 1000 times more than Tokicos and RSR Race springs
Exar-Kun wrote:Good for him. I know the guy, and we've had lots of threads about his choices....and he understands the risks and issues with his setup. Most people don't. I'm sure everyone knows people that have things WRONG, but still work. S-chassis to have good strong bearings, but they can and will beak with stuff like that. I've seen it on 3 cars to date, 2 S13's and an S14. ?
On what size and offset? I know two people that have had wheel bearing problems, both of them running waaayyy mild wheeels (17x7.5 +40ish 17x8 +25). Personally, I feel that wheel offset (on street tires anyway) is way down on the list for things that cause bearings to fail.
Exar-Kun wrote:also, the artificial track width increase by running a low offset wheel will cause in inner edge of the tire to load more than the outside because of leverage, leading to handling issues, as well as increasing the stress the rest of the rotating assembly sees in daily use (like when you hit bumps)?
I don't get this, that sounds like more of a camber problem... But, undeniably a wider track is better for handling (Pontiac says so... DUH). I also really dont see how it could be called artificial? since really the only thing your missing out on is longer suspension links for better geometry.
Exar-Kun wrote:I wouldn't run a 15"x8" wheel at all in the first place. If you arne't going to utilise the increased turn in a brake clearance you get from a larger diameter wheel, you can get plenty of sticky tires on a 15x7 or even the stock SE alloys, and you won't ahve to stretch them, or have clearance issues. I find it odd a 15x8+14 would be so close to the shock body, but since the coilover is angled away from the car, the lower diameter rim would put the flange closer than a larger one..
Zeals have notoriously small lower brackets... I think Ive heard you need a +10 or less on the front to clear a 17x9J
I'd never do a 15x8 either, but some people dig the old school look... I did for a while... when the only Hyperrev I had was from 1996.
I don't want to come off as overly argumentive, I just think its weird your pushing all this stuff in a realitively consertive fitment thread. Prolly would have been better suited for that "look at my +10 18x9.5J Sportmaxes that don't fit thread"
