Need to know what size tires you currently have, then you can determine rolling diameter. Typically, depending on which Z wheels you have, the most common size I've seen is 225/40. Look at the sizes on your stock wheels, then go
HERE and plug the numbers in. You will need to know the diameter, width, tire size, and offset. There you can find out what the differences are/will be. Hopefully you can match the rolling diameter and not change anything. Good luck!
