New Wheels for the Q
goody90q45
Car: 1992 Infiniti Q45 (sold)
I got a good deal ($400) off Craigslist on a set of wheels and tires (and chrome wheel nuts) from an 04 G35 coupe. Front tires are Bridgestone Potenza 225/50-17 93V and rears are Hancock Ventus 235/50ZR-17 96W. All the tires are close to new with about 90% tread left. No fitment issues and I like the look.
Look famliar Andy? Glad we don't live in the same county. There isn't room for us both.
96'er
Car: 1996 Q45
Looks good Mike, now all you need to do is put some lowering spring on it and it will rock.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
96’er wrote:Looks good Mike, now all you need to do is put some lowering spring on it and it will rock.
Or ride and handle well with OEM geometry.
Bastard mix of tires should be solved soon by replacing under load specification front tires with correct 95+ rated Potenzas, even if they are not the best ones!
Ooops! Just noted the Hnakkokies are on the rear. Oh well! Running used tires is like wearing someone elses soiled underwear.
Especially the front whitey tighties!
infinitinut2
Car: 90 Q45 (238K), 92 Q45 (134K) , 92 M30 soft top (145K), 96 Lexus LX 450 (80K), 97 Chevy Burb (250K),
"I got a good deal ($400)..."
I could even be tempted to replace my Fittipauldi 15" for that kind of a deal! Was there much "curb rash" on them? I also like the clean look of your "new" wheels, the Fittipauldis being impossible to keep clean! BUT, my tire installer said the Fittapauldis were some of the truest wheels he had ever worked on! Alas, my Pilot 235s are getting rather long in the tooth! I would like to keep that 235 size, but Michelin no longer making them, with the Exalto 225 being the only game in town worth considering if I stay with the Fittipauldis.
Thanks!
qship96
Car: 1996 Infiniti Q45
infinitinut2 wrote:"I got a good deal ($400)..."
I could even be tempted to replace my Fittipauldi 15" for that kind of a deal! Was there much "curb rash" on them? I also like the clean look of your "new" wheels, the Fittipauldis being impossible to keep clean! BUT, my tire installer said the Fittapauldis were some of the truest wheels he had ever worked on! Alas, my Pilot 235s are getting rather long in the tooth! I would like to keep that 235 size, but Michelin no longer making them, with the Exalto 225 being the only game in town worth considering if I stay with the FittipauldisThanks!
Having gone through 3 sets of the XGT in both 225 V and 235 H, and on my second set of 225/60/15V rated Exaltos......The Exaltos are a MUCH better tire all around, and I got 55,000 miles out of the Exaltos- never made it to 40K with the XGTs
goody90q45
maxnix wrote:Bastard mix of tires should be solved soon by replacing under load specification front tires with correct 95+ rated Potenzas, even if they are not the best ones!
I looked close at the Hancocks to make sure they were the correct load rating and assumed the Potenza's were OK and didn't look. Oops.
infinitinut2 wrote:.....Was there much "curb rash" on them? I also like the clean look of your "new" wheels, the Fittipauldis being impossible to keep clean!
One of the wheeels has rash on all the ribs and the rest are fine. I'd been looking at a set of Fittipaldis for $150 but they would have needed new tires. These seemed like a good deal considering the cost of new tires alone.
qship96 wrote:......The Exaltos are a MUCH better tire all around, and I got 55,000 miles out of the Exaltos- never made it to 40K with the XGTs
I have Exaltos on the 94Q. Excellent tires.
Sorry, no lowering springs for me. I'll eventually get a rear active or touring sway bar and a Jeff Williams FSTB though.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
What kind of Fittipaldis are you looking for?
goody90q45
I'm not now since I got the new wheels.
Infinitiguy19
Still do you mind showing me?
Its not theses are they:
goody90q45
I think they were the OEM BBS wheels. Weren't they dealer installed Fittipaldis?
Infinitiguy19
Well I think those above are fittipalidi, and the dealer installed are BBS.
mxr662
Car: 1990 Q45 Desert Sand 81k Sold
Wheel width Rear 8 Front 7.5Wheel offset Rear +33 Front +30Tire width Rear 255, Front 245Tire aspect 45
My tires are a bit bigger and they rub. Mike have you done any hard cornering?
Infinitiguy19
Wow double vision.
Except one has high and the other has low millage.
goody90q45
mxr662 wrote:My tires are a bit bigger and they rub. Mike have you done any hard cornering?
No rubbing issues with these tires or on the black 90Q that had the same wheels. I've been on a couple of spirited drives with the new setup and the roads at AJ are windy and hilly. This morning I did a few circles in the parking lot just to make sure and had no rubbing on full turns.
My tires are about 0.2" taller front and back than yours so it looks like a width issue rather than a height problem. Come to think of it I had 235/55-17 on the rear of the black 90Q and had no rubbing either.
Good chart:
http://riverviewtire.com/Tireheightchart.html
Modified by goody94q45 at 4:40 PM 1/13/2009
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Looks good mike!
Just so you know you cant go higher than a 245-50-17 on the rear because you will rub. 235-50-17 might be a good fit all around. Also, FWIW the outer clearance on both those wheels are the same so it shouldnt hurt to run 235s on all 4 wheels and rotate them as you would the same, even though the front and rears are different widths (IIRC?)
SFBayQ45
Car: cars
elwesso wrote:Looks good mike!
Does 245/50/17 rub against the fronts, Wes?
silver2k2
Car: 1994 Q45 Ivory Quartz/Tan
looks real nice Mike, we need to meet up again so I can see your new Q
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
goody94q45 wrote:I think they were the OEM BBS wheels. Weren't they dealer installed Fittipaldis?
OEM BBS were genuine BBS, not Fittipaldis.
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
Hello Mike... those wheels look great on that Q45.. and what a great deal with 90% thread on tires!
With G35 rims I prefer stock height all the way. I think they look better at stock height... but that's just my opinion.
Somebooody said something about tires. I have to put it out there that Firestone makes great lasting tires. Mine lasted to its warrantied 40K miles and looked like it had 20K left on them. Although my Q45 created a DEEP thread surrounded gash of metal wire on the insides on the front wheels so I had to get them changed.
socalY33
nice update.
I love that these cars are 5x114, and that so many of the newer models have nice factory wheels.
