No Y50 wheels will require at least .5" spacers.Jesda wrote:I thought 06 M45 wheels wouldnt fit? I guess I was wrong.
I agree with Greg, except I'll add the 350Z 18" Rays to that list. The ones Wes' is running. You won't be able to go wider the ~255/40 on the rear, but they look great and are nice and light.AZhitman wrote:I have the chrome 2004 Q wheels. I'd rank your choices, in order of fitment and load rating:
FX35/FX45 18'sQ45 18'sG35 18's
The M wheels have weird offsets, the G Coupe wheels (19's) are not attractive, and the Alty SE-R's? Bleh.
Based on pricing and availability, I'd say find some 02-05 Q wheels.
What's the stats on those?RobertsnewQ wrote:I like the ones I'm running - 350z touring. THey're cheap, but you have to swap out the front tires.
Rear offset is a TINY bit positive.
How can you not like these??RobertsnewQ wrote:I agree about the stupid little dents in the spokes of the forged 350z wheels.
OEM Bridgestones are crap anyways.
The 8-spoke 02-05 Q45 wheels are available in 7.5 and 8 inch widths in the 18 inch diameter as well as the 7.5 x 17 size (35mm offset on the 17's) as you have in the pics of the 05 Q's.lino wrote:OPTION 3:2005 Q45 Wheels and Tires8-spoke, 7.5 x 18-inch chrome-finished aluminum alloy. 245/45R18 V-rated all-season performance tires.
Got pics? Are you running 245 45 18s?AZhitman wrote:I have the chrome 2004 Q wheels.
Do the FX wheels fit better than the others?AZhitman wrote: I'd rank your choices, in order of fitment and load rating:
What is the offset for the M wheels?AZhitman wrote:The M wheels have weird offsets
So would the 2006 350Z 18" x 9.0" (front) RAYS® fit if I were to use them for all four corners with the P245/40WR18 tires?Rex wrote:
lino wrote:Got pics? Are you running 245 45 18s?
AZhitman wrote:
AZhitman wrote:
AZhitman wrote:... They're a good fit with 255/40ZR18 P-Zeros.
Not that I know of, but they're all 8" wide versus some of the same look Q wheels only being 7.5 wide.lino wrote:Do the FX wheels fit better than the others?
lino wrote:What is the offset for the M wheels?
szhosain wrote:NOTES:
1. The OEM 2006 M35/45 wheels have a very high offset (close to 50mm) and cannot be used on other Infiniti models (using spacers is not recommended!)
2. The OEM 2003/2004 M45 wheels can be used on other Infiniti models since the offset is compatible with many of them.
Depends on what the offset is for the 06 Rays is, I kind of doubt the offset on them is high enough to not pose a rubbing issue or require "additional" camber. Also, with them being this new, it would be enarly impssosble to find them for sale, and paying "dealer costs" would just not make sense.lino wrote:So would the 2006 350Z 18" x 9.0" (front) RAYS® fit if I were to use them for all four corners with the P245/40WR18 tires?
Thanks for the pics! I just remebered your car after seeing those gorgeous pics. I saw the pics a while back. Those wheels really suit the car.Rex wrote:Not that I know of, but they're all 8" wide versus some of the same look Q wheels only being 7.5 wide.
Where can I find the offset information of all these wheels? Do you have any suggestions?Rex wrote:
I toyed with the idea of trying to get 4 rear 05 18" Rays, but I'm not sure they'd fit without some slight "adjustments".
Assuming you can't get the info from a Nissan site, I usually look for back of wheel pics on ebay to see the numbers stamped into the wheel.lino wrote:Where can I find the offset information of all these wheels? Do you have any suggestions?
Just for reference, I'm pretty sure the 19" G35 Rays areFront: 19" x 8" 30mm offsetRear:19" x 8.5" 33mm offsetIWannaS15 wrote:Wow. Very thorough list of OEM wheel choices.
Personally, I love the pre 06 forged Z wheels like Wes's and Keith's. My second choice (based on looks, not fitment) would be the forged 19" G wheels.
