New wheels and lowered, chirping?
locoluna825
Car: 90 240sx coupe
Hey guys, I finally picked up some wheels I wanted. I stuck those coil overs most of you told me not to and I lowered it like 1 1/2 IN or maybe more. They weren't as bad as most of the people said they would be, ride is OK tolerable needs a little more adjusting but ok.
But only thing i noticed wrong is my rear wheel is chirping SOMETIMES, (Not sure which but i think its the right rear wheel.) When I make right turns. Didn't before. .
Is this due to stiffer suspension/ traction, or something. Anyone notice this when lowering there cars or adding coil overs?
I am running to different tires treads on the rear of the car. car has an open differential. I have not yet got an alignment.
Thanks just wanna know if anyone ever experience this? a
ill get some pictures up tomorrow for you all to enjoy. car looks good
SXmeUP
Car: searching
do you have a welded diff?if not... somethings probably out of alignment or got bent...
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
its your 240 crying softly due to its suspension rape you just committed.
put REAL suspension on it...
locoluna825
Car: 90 240sx coupe
mrgreeneyes wrote:its your 240 crying softly due to its suspension rape you just committed.
lol thanks, but i don't think there's anything wrong with what i just did, shocks aren't blown its not beating me up either, and no strange noises or vibrations. i don't need a 1500 suspension on my car.
No welded diff, stock open diff
Modified by locoluna825 at 10:27 PM 10/13/2009
zeause
What kinda suspension is this fake suspension anyhows?
Dazzla
It's fine. It's the coilovers that are chirping. You need to grease up the springs. I'm assuming your running Megans judging by the negative attitude...
Read through this and you will fix the problem. http://forums.evolutionm.net/e....html
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
Dazzla wrote:I'm assuming your running Megans judging by the negative attitude...
i was curious myself, so i did some digging and found that they're k-sports.
locoluna825
Car: 90 240sx coupe
yes ksport.... and the tire is chirping not the coilover, someone wanna buy me some kyb struts and lowering springs instead?
kouki munster
Car: 97 base 240
A tire is probably rubbing the fender.
