nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Wed Apr 23, 2008 9:35 am
I just had my brake fluid changed by a general mechanic shop because I didn't have time to do it myself. They didn't even mention the Speedbleeders. They're very simple and make the process easier, so any shop that tells you they can't deal with them is clearly too stupid to work on a car.
Where in the Atlanta area are you?
Yet again, from what you've described I have to say that I don't think it will be safe to drive. They'll be squishy in terms of feel, as I've described, and when they are squishy that means function is diminished. Your stops will be very long at best, which in the real world is unsafe.
Either get Speedbleeders and do all of the work yourself, or take it to the shop and foot the bill for them to do all the work.
Drift - What you've described is not a bleeder, that's a catch can of sorts for the brake fluid that is bled off. The bleeder is the valve on the brake assembly that allows you to pump out the old fluid.
A Speedbleeder is a threaded one-way valve. It directly replaces the stock bleeder and makes it such that you simply set up something to drain into and start pumping, checking the fluid level every few pumps to make sure you don't accidentally run dry.
