One_Love »
https://forums.nicoclub.com/one-love-u30730.html
Tue Aug 22, 2006 1:54 pm
* HR stands for High Response (or High Revolution)* 5th Generation of the VQ.* Redline increase to 7500rpm* Redesigned block for increased rigidity* Complete symmetrical intake and exhaust systems* Worldwide first hydrogen free DLC (Diamond Like Carbon) [hu] due to coding adoption decrease* Setting electromagnetism VTC on exhaust cam side in addition to the oil pressure VTC of air inlet cam side,* Adoption of isometric exhaust manifold* Higher compression ratio: 10.6:1 (previously 10.3:1) NISSAN DEVELOPS NEW-GENERATION V6 ENGINES --Engines to power all-new Skyline to be released this autumn--
TOKYO (Aug. 22, 2006)--Nissan Motor Co., Ltd., has newly developed two new-generation six-cylinder V-type engines for front-engine, rear-wheel-drive vehicles featuring powerful performance and improved environmental friendliness.
The 3.5L VQ35HR and 2.5L VQ25HR engines will be built at Nissan's Iwaki Plant in Fukushima Prefecture and will be equipped in the all-new Skyline to be released this autumn in Japan, as well as the US where the model is sold as the Infiniti G35.
Featuring newly designed engine blocks and other key components, the engines offer smooth transition to top-in-class level engine speed of 7,500 revolutions per minute drawing upon the "smooth transition" concept of the popular VQ engine, the only engine in the world to appear on Ward's 10-Best Engines list for 12 consecutive years.
The engines achieve a 10% improvement in fuel efficiency compared to vehicles equipped with the existing VQ engine and top-in-class Super Ultra-Low Emission Vehicle level emissions. SU-LEVs have 75% or less nitrogen oxide (NOx) and hydrocarbon (HC) emissions than those stipulated by Japan's 2005 exhaust emission standards.
The letters "HR" in VQ35HR and VQ25HR stand for "high revolution" and "high response."
Nissan began VQ engine production in 1994 and has produced a cumulative total of 5.5 million units as of last fiscal year, ended March 31, 2006.
Main specifications of the VQ35HR and VQ25HR engines:
Smooth transition to top-in-class level engine speed of 7,500 rpm
* Reduction of weight and friction through adoption of asymetrical piston skirt configuration* Reduction of piston-side force through lengthening of con rod* Addition of rudder frame, newly-designed cylinder block with significantly improved rigidity
Thrilling revving sound and top-in-class output
* Adoption of perfectly symmetrical intake system* Adoption of continuously variable valve timing control (CVTC) for intake side and electromagnetic valve timing control (e-VTC) for exhaust side* Reduction of intake resistance through adoption of symmetrical twin intake system and straight intake port* Adoption of isometric exhaust manifold and perfectly symmetrical exhaust system
Improvement of fuel-efficiency and emission cleanliness
* Reduction of friction through adoption of world's first hydrogen-free, diamond-like carbon (DLC) coating* Adoption of catalyst substrate with ultra-low heat mass, super-ignition iridium spark plug and fast light-off O2 sensor control
