New VH45 - S-Chassis Mounts
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
DRFTBLD
Car: 89 S13 VH45DETT
05 Ford F-150 Drift Support
91 S13 Tester
08 Ford Focus
Brand new Kisuu VH45 to S-Chassis Mounts, by Driftbuild - Prototype 1.3
These are the new mounts I have been working on. They tested good and solid on all test's we put them through. with out issue. I spoke with the Fabricators today and the only change from shown in the pictures is an oval hole (opposed to 1 single hole) for the chassis side to allow for different placements based on your specific set up and which adapter you are running. They should be fine with both Mazworx and Xcessive adapters but they were designed to fit our own (coming soon). And unlike ANY other brand on the market they come with a full LIFETIME warranty.
They use a solid 1/4inch plate set which has been hardened. They are connected by three 1inch tubes placed to spread the load across the entire mounting surface to enable the weight to be as close to OEM mount specs as possible. These are currently finished in Wrinkle black Power coat for longer life and for looks, however we will be eventually shifting the color over to our signature Kisuu gold (same color as our fuel rails currently are). These come with the hardware required for mounting and instructions. The design of these mounts also allow for you to remove the oil adapter (oil feed neck) while the mounts are installed on the engine.
klh6686
Car: '92 FB stock daily
'90 FB w/ RB20
'92 FB w/ VH45
they look sick, nice work! in for pricing
pwrdbyNissan
Car: 1992 240sx Hatch
Vh Swap in Progress..
Any News on these in need of a pair badly?
DRFTBLD
91 S13 Tester
08 Ford Focus
We are trying to find a new fabricator for these after the last company we had was not able to complete the task. We are hoping to have another place by the end of next week lined up and should be able to have the first sets out the week after that.
Sorry for the delay but stay tuned and we will be getting these out as soon as possible.
Return to “VH45DE / VK45DE / VK56DE Forum”
