New Versa SL - Driver's Side Vibration
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
matt.nantais
Car: 2008 Nissan Versa SL
I just purchased a 2008 Versa SL Hatchback. Immediately I noticed a metallic sounding vibration coming from the driver's side of the car. I can hear it at all speeds. It sounds like its coming from inside the driver's door or the rear driver's side door. Has anyone encountered this problem before? Is it possible something is loose? Any help is greatly appreciated. MN
srellim234
Car: 2007 Nissan Versa SL hatch w/CVT
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
I haven't experienced anything like that with my 2007.
bikeman
matt.nantais wrote: Has anyone encountered this problem before?
No.
matt.nantais wrote: Is it possible something is loose?
Good guess. Have your dealer locate and fix the problem.
David
kaze0
I get it when the window is partially open. Taking to dealer this Tuesday.
aver03
Car: 2008 Versa S
I have an '08 S that started rattling in the driver's door about a month after I bought it. Took it to the dealer at the first oil change, and they said the door needed to be aligned. Driver's front door is difficult to close after the fix, but it stopped rattling. Well, for a whole week. Now it rattles above 55mph and is difficult to close the door. Guess I'm getting it checked again at the next oil change. I hope you have better luck.
Otherwise, I love the Versa.
Return to “Versa Technical Discussions”
